Home > Maintenance & Modifications > Confused about tyres and wheels!
Crafty1980
I've just been reading this months LRO mag and the first article about the black TD5.
He's put on cooper discovery SST tyres at 285/75 R16...
But my standard tyres on my XS are 235/85 R16...
So doesn't that mean he's put on smaller diameter wheels that standard?!? They look much bigger than standard on the pics in the magazine!
...or am I a nonce and getting something wrong??
Post #362289 5th Oct 2014 11:30am
mk1collector
The 75 is the percentage of the width which is 285 so will be bigger than 235/85's Thumbs Up
235's have 199ish mm sidewall
285's have 213ish mm sidewall
Post #362295 5th Oct 2014 12:48pm
AndrewS
To keep the rolling radius as close as possible to the original spec, the side wall dimension is reduced as the tyre width increases.
Post #362298 5th Oct 2014 1:06pm
Crafty1980
Oh it's a PERCENTAGE! DOH. For some reason I always thought the 75/85 etc was the actual depth of the wall. i.e. 75mm 85mm etc... That explains a lot!
Everyday is a school day! Smile Thumbs Up
Post #362313 5th Oct 2014 2:47pm
munch90
if you need to different check sizes etc there are quite a lot of tyre websites that have tyre calulators on them , put old size and new size and its gives you rolling radius , height & % etc etc
Post #362316 5th Oct 2014 2:56pm
NJSS
This site may help:-
http://www.alloywheels.com/Tyre_Calculator
NJSS 2016 Discovery 4 Landmark
2011 Mercedes Benz SL350 (R230)
1973 MG B GT V8 - 3.9L John Eales engine, 5 speed R380 gearbox, since 1975.
1959 MGA roadster - 1.9L Peter Burgess Engine - 5 speed gearbox
Past LRs - Multiple FFRs, Discos & a Series I - some petrol, some diesel,
none Electric yet.
There are 10 types of people in this world: Those who understand binary, and those who don’t.
Post #362317 5th Oct 2014 2:57pm
Crafty1980
Ok, so the guy in the magazine has increased his overall tyre size quite a bit then by all accounts.
So what happens then with things like VOSA? MPH gauge?
He's going to increase the amount of power needed to push off from first gear too I'm guessing? Or is it so negligible that there's no need to worry about it?
Post #362325 5th Oct 2014 3:46pm
munch90
they say you shouldn't go above 2.5% difference , if you use a tyre calculator it will tell you the % gain or loss , yes if you go up or down in tyre size diameter gearing will change (bigger tyre diameter slower pull away higher top speed (if engine will pull the higher gearing ) smaller diameter faster pull away , slower top speed
235 85 16 is a tall ish tyre anyway as standard profile is 80 sometimes marked as 235/16 or 235/80/16
there difference is 3.47% (that's if his standard tyre was a 235/85/16 and new was 285/75/16 ) so really a bit over what they recommend , but maybe he has altered speedo ratio to suit
each tyre size if fitted as standard will have its own speedo ratio unless they all come out same diameter
Post #362364 5th Oct 2014 6:26pm
I run 285/75 R16 BFG KMII Muds and the speedo is now spot on when checked with a Home Office approved device. All vehicles have speedos which over-read (indicate a higher speed than you are travelling at) by design. Larger tyres often compensate for this.
Post #362428 5th Oct 2014 9:13pm
dorsetsmith
land Rover 90/110 speedo drive gears
Colour: blue/20 teeth - Part number: FRC3310 - Tyres: 7.50/16 or 235/85/16
Colour: green/21 teeth - Part number: FRC3311
Colour: yellow/22 teeth - Part number: FRC3312 - Tyres: 205/16 tyres
Colour: red/24 teeth - Part number: FRC3313
Post #362440 5th Oct 2014 9:30pm
Crafty1980
Is the speedo on new Pumas still analogue gears? Or are they now controlled as part of the ECU?
Post #362527 6th Oct 2014 8:28am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Ashcroft do a 'speedo correction kit' for Puma Defenders. This would solve the problem, although I found that running 285/65 18s my speedo is now spot on rather than slightly optimistic as standard.
http://www.ashcroft-transmissions.co.uk/sp...n-kit.html 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #362530 6th Oct 2014 8:50am
