![]() | Home > Wheels & Tyres > Trye pressure guages |
| landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134
Dial ones are pretty good, easy to read (which is good when your eyesights getting crap - it's an age thing!)...and I usually find with digi things the batterys run out just when you want to use them...but they are probably more accurate than the others! 1959 Series 2 Ragtop
1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
I bought a "cheap" Halfrauds digital one about 7 years ago and it still works!
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
I've got a PCL pressure gauge/inflator. Calibrated twice a year, and not cheap at about £50 but it's never let me down during daily use! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
devon4x4 have a good digital one
http://www.devon4x4.com/index.php?page=sho...;Itemid=14 |
| Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
I bought a brand new rather expensive PCL 'professional' grade analogue pressure gauge - Made in Sheffield - no batteries or electronics to degrade and thought it would do the business for many years. It's now sitting in the hall cupboard awaiting what might be a one-way ticket back to Sheffield. After using it on several vehicles that I own - I'm totally unconvinced as to its accuracy. Currently using a rather cheapo Halfords plastic unit that appears to give more consistent and accurate readings. I also have a PCL tyre inflator and the integral gauge on that unit appears even less accurate. |
