Home > For Sale & Wanted > [For Sale]Pair Forward Facing seats, belts & brackets
Mean Green
Complete kit to install forward facing seats in the load bay of a Defender. Includes Forward facing seats (x2) in black vinyl,
seat belt mounting brackets, seats belts and floor mounted ‘butterfly’.
Seats are used but in excellent condition with no tears or marks (flaking paint and slight rusting on the hinge).
The seat frame is bolted at the hinge to the wheel arch, with the legs taking the weight of the passenger on the floor.
When folded away the seat stows neatly on to the wheel arch leaving the load area totally free apart from the floor belts.
To use the seat it is simply released from its stowed position (folded into the load area) and the support leg will drop down into position and secured with a thumb screw.
The seat back will recline into its upright position and fix in place with another thumb screw.
The seat relies on a 4 point seat belt for safety which are included. The belt buckle section is permanently fixed to the rear floor centre between the seats when in use
Also included are the seatbelt mounting brackets (as fitted in current TDCi Defenders) that fit on the rear quarter around rear quarter window. The bracket bolts to both the tub capping and roof/side panel join and has no need to drill additional holes.
The seats are located in near Kilmarnock, Scotland.
£300 + P&P (although given size and weight collection would be preferred)
Post #360964 29th Sep 2014 2:16pm
