Home > Puma (Tdci) > 110" HD Rear Axle?
MK
110" HD Rear Axle?
I saw this on the workshop manual:
Axle - 110/130
Disassembly
1 . NOTE:
Remove differential assembly.
*This procedure is applicable to 110 and 130 models from the following VIN's:
�� 110 Non ABS - 638164
�� 110 Heavy Duty and 130, Non ABS - 638224
�� 110 Heavy Duty and 130, With ABS - 638134
So, what is a HD axle?
thanks
MK Puma 110" SW
Post #31225 2nd May 2010 12:41am
harveyg77
Thought it was suspension ie 3050kg for normal and 3500kg for HD.
Post #31236 2nd May 2010 9:26am
AndrewS
Heavy Duty Thumbs Up 130's have feeling's as well you know Smile
Post #31266 2nd May 2010 4:06pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Someone told me they have the Wolf rear axle but i may be wrong.
Post #31284 2nd May 2010 8:35pm
MK
I thought all 110" (2007 on at least) had wolfs Puma 110" SW
Post #31290 2nd May 2010 9:24pm
alantd
I too thought all post 2007 110s are using the same rear axle, diff and springs. One that started out as a 2.4 TDCi 110 XS
Post #31323 3rd May 2010 9:45am
The salisbury was avaiable in standard and HD forms... the HD has standard internals, just a heavier casing (there were extra webbings and welds inside, especially where the tubes join the main differential housing)
Just looking though microcat at the puma and late Td5 defenders. a HD rear axle is optional on 110's, and standard on 130's, but looking through the individual parts, there seems to be no difference in bits... there is the 4 pin rear differential, which seems standard on 110's (or at least, the later ones), and standard on all 130s. same halfshafts,brakes,stub axles on "standard" and "HD", so what actually is different is hard to see.
Front axles are available in standard and HD. difference being vented discs and 4 pin differential on the HD ones.
Post #31340 3rd May 2010 2:43pm
