![]() | Home > For Sale & Wanted > [For Sale] First Four Low Line Winch Bumper |
| willinone Member Since: 25 Feb 2014 Location: Essex Posts: 20
do you have to cut the grill out to fit the winch with this bumper?
| Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52
Just checked FF's site and the answer is yes.
'Please note, the grille panel and grille needs to be modified to fit this bumper.' Also check as this bumper is winch specific. I would have had it off you Mo but it won't take the Superwinch Husky 8 Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
thanks for your help
sorry I don't want to cut my grille so I won't take it |
| Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756
To be fair, not many winch bumpers take the Husky other than ones made specifically for them as they have such a unique footprint. Similarly the 8274 needs a fairly specific bumper. Most other winches out there should fit this and any other generic winch bumpers. The trouble with bumpers that do not require modification of the grill is that they stick out too far, look gash, and compromise you approach angle.
exactly right, these are the best bumpers for looks & offroading. Unfortunately, my tdci is a little bit nicer than my old 300tdi and I don't want to start cutting lumps out of it
| Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861
this will take any standard low line winch
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2420
I have a non air con front end and i didn't need to cut the grille
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
If you get a replacement front panel you can remove your nice, painted one and replace with the cut panel. When/if you want to return to original condition just bolt the original panel in.
Best of both worlds... Cheers Simon |
Sensible offers welcome
| All times are GMT |
