![]() | Home > Technical > R380 2nd gear problem |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Mine was massively improved by using fully synthetic oil and additives.
Andy |
| stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342
use MTF 75w80 or 75w90.
Why are you using ATF in an R380 gearbox? Steve Discovery 3 HSE BMW 330i Coupe |
| souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153
Steve
Read the thread. ATF was in the box from new i guess. I replaced it as per rave. Im now using MTF94 Thanks guys |
| silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99
not in a R380 gearbox the oil is too thick use MTF94 or at a push try 10w40 fully sync engine oil (temporarily only) |
| Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320
I had the same problem in my D2 and the 2nd gear was no where to be seen until the car had warmed up, took it to a landy indy and we drained the box and put in ATF, the change was 90% better but the damage had already been done due to MTF being put in it but this was a R380Q box not just a R380
| All times are GMT |
