![]() | Home > Td5 > So has anyone failed their MOT with a de-cat'd TD5 yet? |
| Marlin.45 Member Since: 20 May 2014 Location: Llangadog, Carmarthenshire Posts: 54
As per the title really. What experience has anyone had with a previously CAT equipped TD5 with respect to their MOT? Just wondering
Paul 2006 TD5 90 County 1961 MF35 |
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2529
Passed 4 months ago 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
| epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395
Passed no problem a couple of months ago
But were they both previously CAT'd? 2002 is an early one and exempt anyway AFAIK. 2006 TD5 90 County
1961 MF35 |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
You are correct about them being exempt. With a 2007 vehicle you are not! Why not 'sound out' your MOT tester like I did and then you can be prepared?
Puma but same year.... http://www.defender2.net/forum/topic28888.html?highlight=cat If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91
Passed Friday no probs 03 plate
^ Also exempt.
Mine had a cat last year. Its a 2004 TD5
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
You will have to take into consideration the ignorance or the observation of the tester,just coz it past this year doesn't mean it will pass next year,or that your mates will pass at another garage. Pov.spec,ftw. 2006, 110,TD5.
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
I sounded the garage out with a call before taking mine in, passed no problem. (2006)
I thought wrongly vehicles before MY2005 were exempt....apparently not.
https://www.gov.uk/government/uploads/syst...1-2014.pdf If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| JimboD3 Member Since: 09 Apr 2013 Location: Ware, Herts Posts: 55
If I'm reading the notice correctly, then doesn't the title explain all ?
1 1 Presence of Catalysts and Particulate Filters on Diesel Powered Vehicles AEs & NTs Classes 4, 5, 7 So the check for a Cat is only applicable to vehicles tested at Class 4, 5 or 7 as per the link that K9F added. Jim Td5 110 HD Hardtop.......not quite standard |
Well the 90 went in for it's test today sans CAT..............and passed!
I didn't start asking the tester the why's and where for's 2006 TD5 90 County 1961 MF35 |
| Derrickthedefender Member Since: 28 Jan 2014 Location: South Posts: 294
just bought a bloody CAT for mine ready for test day, just to be safe... A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Yes the name for my 90 is Derrick! |
