![]() | Home > Maintenance & Modifications > Wipac LEDs flashing speed |
you need to change the flasher unit to a led electronic one , easy to do just remove old one and fit new one , 30sec job
or fit resisters to the lamps , longer job and not as easy as replacing flasher unit |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
Need one of these...
http://www.flatdoguk.com/12v%2Dled%2Dflasher%2Dunit%7E935 |
Wangers Member Since: 19 Jan 2013 Location: West London Posts: 265 ![]() ![]() ![]() |
If a bulb Blows then there is a loss of resistance hence the rapid flash.
LED drawes less in the first instance so unit thinks there is one blown. Either need to put in resistors to each bulb or change relay. TY&GN 10 years in a WOLF, WIMIK and Snatch and this is all I have to show! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20910 ![]() ![]() |
Here is what you need :
http://www.ebay.co.uk/itm/RDX-4-Pin-Flashe...5af941eb68 |
