![]() | Home > Technical > Advise on steering box adjustment |
Is the nut working loose on the drop arm of the steering box? I had that with mine so re-tightened it and added another nut and tightened against the first.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Check the steering shaft universal joints too as these commonly cause play in the steering.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
its 2,2 so cant be that old , what year and miles it done ?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8379 ![]() ![]() ![]() |
Steering box adj should be last thing to consider. All tre's are tight? Drop arm ball joint ok and as above drop arm bolt tight? Plus steering ujs are fitted fight and tight Cheers
