![]() | Home > My Defender > DEFENDER 110 TD5 SUSPENSION PROBLEM |
if its bottoming out then your springs are too soft. you cant really compare old springs and new springs as they may sag.
Also, id have assumed the bump stops on the axle would stop the damper completely bottoming out. |
albertdefender Member Since: 19 Feb 2014 Location: girona Posts: 749 ![]() ![]() |
Hi mikeh501
Yes you're right about the bump stops but if the length of the shock is shorter than the distance of the bump to axle,,,,the shock breaks. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6000 ![]() ![]() |
Sorry to say, but terrafirma suspension is rubbish. I would suggest fitting decent quality springs and dampers.
I've had a few terrafirma suspension parts, and also other mates trucks, all have been removed and scrapped Andy |
Hi Andy I heard this before, if I don't find an answer I will put the genuine springs.
Thanks anyway. |
