Home > Puma (Tdci) > Glow plugs?
ickle
Glow plugs?
Hi Folks,
My 110 2.4tdci approx. 85k miles has started to play up when cold. It starts instantly either with or without using the glow plug timer, but either way when you go to pull away, there is no power, its like its on 2 1/2 cylinders for maybe two or three seconds, then whoosh, big belt of black smoke and we're away.
It only happened first thing in the morning and seems to be worse when its colder.
I'm either guessing that its glow plugs or is there another temperature sensor anywhere?
Is there a simple way to test the plugs or at approx. £12 each do I swap them out to try?
Cheers Keith
Post #353620 25th Aug 2014 9:06pm
Could be fuel filter needs changing, when was the last service?
Post #353623 25th Aug 2014 9:11pm
ickle
Hi Steve,
filter was done in June with oils etc plus major brake overhaul, prior to holiday trip to France.
Runs perfectly otherwise though, just did 80 up the dual carriageway hill out of Monmouth so fuels getting through!
Cheers Keith
Post #353624 25th Aug 2014 9:17pm
munch90
never heard of glow plugs causing that sort of thing , seen a lot on transits the wiring burnt out to the plugs due to short on plugs and never known anyone bother to repair it and they still start and run fine
think to be honest on most modern diesels ( in uk ) you could disconnect the plugs and you wouldn't notice a difference maybe in deepest winter not start on the button , but never known a transit not start or run ok with plugs not working
is fuel running back overnight due to air leak ?
Post #353627 25th Aug 2014 9:21pm
ickle
Thanks Munch,
How would I know if there was & where would I look for a an air leak into the fuel system?
If there was a leak on the suction side, would it not pull air in all the time so hoofing up the A40 wouldn't be possible?
Cheers Keith
Post #353638 25th Aug 2014 9:53pm
munch90
modern diesels can put up with quite a bit of air in diesel , quite often on a diesel with clear pipes you see bubbles going up the pipe and they still run ok
but running back leaves in big long bubble which could be a problem
if you start it let run for a min does it still do it ?
or hold tick over up a bit when first started does it still do it? ( not flat out just up a bit! )
is it down on power or actually misfiring ?
[u]check the filter on tight , easy to tighten to first notch and not to second , give it a twist by hand to make sure[/u]
Post #353647 25th Aug 2014 10:06pm
ickle
Cheers Munch
I will try the fast tick over and other bits tomorrow, but yes after the first three seconds it runs superbly. It has always been a bit 'lurchy' at very slow speeds, trickling along through a car park etc. and sometimes smoky especially when cold, first and second gear, but otherwise really sweet.
I'll report back tomorrow!
Thanks again.
Keith
Post #353650 25th Aug 2014 10:18pm
munch90
Post #353651 25th Aug 2014 10:20pm
ickle
Thanks Munch,
Filter was reluctant to turn but then did another 90 degrees to a definite stop, so hopefully you've cured it!
It started up fine, (but obviously if the filter has been letting air in there would be a fault still today) and picked the revs up, it coughed and spluttered for about 3 seconds and then ran fine, nipped round the block and its great - will try again in the morning.
Cheers Keith
Post #353835 26th Aug 2014 8:05pm
munch90
yea ,be handy if that's it , fingers crossed
Post #353870 26th Aug 2014 9:17pm
munch90
how did you get on ? any good
Post #354306 28th Aug 2014 10:59pm
ickle
Hi Munch,
Tried it very quickly this morning, unfortunately brought it up to approx 1300 rpm and it still coughed and spluttered for a few seconds, not had chance to drive it yet though....
Best regards
Keith
Post #354438 29th Aug 2014 7:30pm
dgardel
Italy
When the car cough and splut, are the injectors noisy?
If yes should be the fuel filter or the fuel lines partially clogged Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #354525 30th Aug 2014 8:43am
ickle
Hi Danielle,
No, no injector noise at all, it coughs and splutters, throws out a load of blue smoke that turns quickly to black smoke and then clears and runs as sweet as a nut.
I'll try and video it in the morning.
Cheers Keith
Post #354582 30th Aug 2014 3:58pm
munch90
blue smoke is normally oil burning
check oil level?
oil in breather hose ?
check turbo ?
Post #354584 30th Aug 2014 4:05pm
