Home > Tdi > 300tdi booming under load?????
Page 3 of 4 <1234>
g-mack
yuup, its rather loud and very annoying.
did a little more playing today and noticed it doesn't need to be under load. so its definitely at certain rev range. doesn't matter what gear or speed, video was shot at roughly 5mph!
when driving in 5th at 65 no booming at that speed, let foot off go pedal and let the engine slow it down to 40mph as the revs drop the booming starts.
so it booms when accelerating and decelerating!
removed cyclone breather from air intake incase there was back pressure in the air intake, nope no different. another go with air pipe off turbo (intake side) massive sucking noise but booming still there.
so im ruling out induction noises!
thinking about investigating engine mounts next. as this problem came on gradually and not suddenly! My 109 thread
my youtube channel
Post #359992 24th Sep 2014 8:35pm
shaggydog
Engine and gearbox mounts are a good shout.
Also check your exhaust rubbers and what they attach to.
Post #360001 24th Sep 2014 9:13pm
g-mack
update:
changed OS engine mount for new gen part, this afternoon. booming is STILL there!! Big Cry Big Cry
it may be a little better though but not driven it enough to decide. suppose i will have to do other side next!! this is getting daft!!! My 109 thread
my youtube channel
Post #362891 7th Oct 2014 4:14pm
Fatboy Slim
Wales
Is your cam timing ok?
Post #362907 7th Oct 2014 4:58pm
g-mack
not been checked in a while, could that cause booming? My 109 thread
my youtube channel
Post #362909 7th Oct 2014 5:14pm
Fatboy Slim
Wales
Could do. I had a 200 once that was very similar to that, the cam pulley was loose and had fretted the woodruff key on the cam. Easy to check on a 300.
Post #362926 7th Oct 2014 5:55pm
g-mack
I still have this awful booming noise under load and decided to have another crack at finding what the hell is causing it!
removed ALL associated pipe work up to turbo to eliminate vibration from it. noise still there just moved to turbo inlet!!
finally admitted defeat and took it to a garage!. timing is fine engine revs freely, no smoke, no stutters or hesitation.
the wastage appears to be seized closed!!
so thats my next job freeing that up.
the theory is gate stuck closed(more likely not tightly closed) exhaust gasses have nowhere to go and building up pressure!
can anyone confirm my theory or am i just clutching at straws!! My 109 thread
my youtube channel
Post #445839 13th Aug 2015 5:46pm
munch90
Be honest i dont think the waste gate would cause that and from a seized waste gate you would get over boosting .
Waste gate can be hard to diagnose, because they dont move much at all when revved stationery as the engine isnt under any load
people often think they move a lot , but revving stationery it might only move 1-3mm on the rod
didnt you have the head off a while ago ?
Post #445861 13th Aug 2015 7:16pm
g-mack
yea had a new head on last year.
im not trying to watch the WG move, I'm physically trying to move it with force!!
I'm really running out of options here Big Cry My 109 thread
my youtube channel
Post #445863 13th Aug 2015 7:28pm
munch90
There on quite a strong spring ! Normally you need to use a lever to try them
Is all the pipe from filter to turbo standard ?
Post #445865 13th Aug 2015 7:34pm
g-mack
yep all standard.this noise is definitely coming from the inlet plenum chamber. My 109 thread
my youtube channel
Post #445869 13th Aug 2015 7:47pm
munch90
Real odd one that !
Post #445872 13th Aug 2015 7:59pm
g-mack
tell me about it!!! My 109 thread
my youtube channel
Post #445875 13th Aug 2015 8:21pm
g-mack
right turbo all back on, pulls a little better BUT booming still there!.
off to find a nice cliff to drive off now Evil or Very Mad Evil or Very Mad My 109 thread
my youtube channel
Post #447399 19th Aug 2015 4:06pm
shaggydog
Big Cry
Ok so you have done
New head
New centre exhaust
New engine and gearbox rubbers
Checked timing
New exhaust rubbers
Cleaned intercooler and checked turbo pipework
Just trying to think what is left to do or look at Sad
Only thing I can think of is that your exhaust is resonating with a body panel at a certain rev range. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #447493 19th Aug 2015 7:55pm
Page 3 of 4 <1234>
