Home > In Car Electronics > Blue Sea Relay activation Voltage
Riyo
Scotland 2012 Defender 110 Puma 2.2 SW Santorini Black
Hi,
Does anyone know what voltage the blue sea 500A relay connects the batteries together at?
I have installed mine and when i leave it in auto on the switch the red lights are still on the next day after leaving it prked overnight, i can only assume the voltage of the batteries are remaining above the relay cutout threshold.
Thanks
Post #350685 9th Aug 2014 10:20pm
VeeTee
Netherlands
I assume you have seen this? Cheers, Vincent
MySite
Post #350702 10th Aug 2014 7:57am
munch90
just read on bluesea website the voltage has to be 13 volts for 2 mins to connect and batterys have to drop to 12.75 volts for 30 secs to disconnect
Post #350724 10th Aug 2014 9:51am
Riyo
thanks for the replies, i measured the battery voltages and they are 12.87 and 13v with the engine off... i guess i need some load on the battery then to bring the voltage down enough for the relay to disconnect the batteries.
Post #350751 10th Aug 2014 12:19pm
