Home > In Car Electronics > rca cable
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
rca cable
I am thinking of fitting a focal or kicker active sub into td5 90 xs as ot has aircon what would be the best route to run the rca cables as from what i can see there is no room to poke them down the back of the radio like the std loom goes as the hole is far too small?
Any suggestions
john 2004 TD5 Defender 90 xs station wagon
Post #350074 7th Aug 2014 7:52am
barbel jim
You should find room somewhere! Try poking a separate thickish piece of wire through first. eg welding rod, coat hanger . A small bit of foam gaffer tapped to the end will stop you damaging stuff Thumbs Up
Post #350083 7th Aug 2014 8:54am
Send them on their own indoor can't route.
Mine go down the drivers sued just up and left of the clutch, you'll see a gap straight through there if you look up from the footwell. Then go under the matting / carpeting.
Mine then goes between the handbrake and gearbox tunnel and then on up under my matting. (Or carpet)
Thumbs Up
Post #350095 7th Aug 2014 10:24am
johnszs
Cheers for the tips i will have alook at lunch and report back 2004 TD5 Defender 90 xs station wagon
Post #350099 7th Aug 2014 10:57am
Did you manage to have a gander John?
Post #350166 7th Aug 2014 5:20pm
johnszs
Yes steve i did have a look, de to me having too many accessorys behind their it doesnt look promising bit i might get the file/holesaw set out Whistle
the focal sub seams to come with iso wiring and no rca cables so i am going to look more closely at this as it could be the easy answer if it will mount to the back of the cubby 2004 TD5 Defender 90 xs station wagon
Post #350281 8th Aug 2014 7:02am
