![]() | Home > Puma (Tdci) > Alpine radio problems |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20910 ![]() ![]() |
So I've just read, you can't use the front port for iPod only for a USB flash drive.
You can use the rear socket though but you will need the iPod cable from Alpine. Exactly the same as my Kenwood works, no doubt the cable is pricey. The Kenwood cable is nearly £30 |
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 99 ![]() ![]() |
Now that's peculiar, in the handbook it clearly says to connect an MP3 player or similar device!
I would call landrover but I think they wouldn't have a clue! |
An MP3 player can be different in file format, also using a 3.5mm audio jack in some cases.
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 ![]() ![]() ![]() |
Why not bluetooth your tunes to the head unit and just charge via the USB?
Bluetooth works brilliantly on mine, had my phone and ipad hooked up numerous times and everything works fine. |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
My iphone works fine on my alpine head. I plug it in the front everyday. It won't however charge my ipad.
I had an issue a while back and found my lead was at fault. |
Well, I have the alpine cde-130r, which according to the alpine manual on their website, it has no Bluetooth and only allows USB sticks. So I guess it all depends what LR put in as to what works. It bears no relation to the defender handbook as far as I can tell, it's ok as I can use the jack plug to connect the iphone.
Sorry I have the upgraded Bluetooth one. Don't take any notice of my comments. Sorry
No worry ro key, any input is a help and I appreciate you taking the time to give suggestions.
Thanks |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
When you press the source button what options are you given?
Andy |
Hi Andy,
Only three options, rds, regional and pi seek, so now I which radio it is and I have the correct instructions. At least that mystery is solved! |
Does it not list USB, tuner, iPod ect.?
in the defender owners manual YES, in the Alpine user manual it states that the usb can only be used for a USB storage device. Unfortunately that seems to be how it works. So I think the LR manual is describing a more upmarket version.
Check the back for the USB there..
Will do
thanks to all for your help |
