![]() | Home > Puma (Tdci) > puma gearchange clunking |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5980 ![]() ![]() |
Yes mate
My 10 reg is at 45 thou miles, and I've only had it 9months, and steering guard fitted about 6 months.
I now can't stop driving it, it's fun king great, best drive ever, zero play great drive, fun, fun. Andy |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
My 90 is a 2011 and the build sheet says 2 pin diff, I think only 110 and 130 had 4 pin in 2011 DEFENDER 90 TDCI XS,
Yes that's correct, only 110's got given the four pin mid 10 reg. 90's have two pin.
Andy |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
I have a 2011 110 X-Tech and the build sheet still says 2 pin front diff. See here: ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Oh. Not good, what's the drive like? Any clonking?
Does it show the manufacture date? Andy |
Yep, pretty clunky.
Tried to find build date but can't find it on Topix? |
Just looking at your avatar, so thought may have been built early before shipping out to you.
Would recommend a visual check through the diff filler hole, saved me some trouble. Andy |
Aaahhhhh....how could I forget....
My front diff was replaced just 3 months ago due to accident damage. I hope and believe they would have replaced it with a 4 pin??? |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 ![]() ![]() |
It looks like a visual check will be the only way of knowing for sure. Doesn't look like LR's record keeping has improved over the years. If you talk to the series boys, what the records say, and what was built or exported can be a little different. My Defender and travels
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17872 ![]() ![]() ![]() |
Bearing in mind that your build spec also says you have a "2 pin" rear diff when you have a P38 diff, I wonder if this is confusion caused by nomenclature. Remember that the two options are firstly a diff with a single cross-pin which carries two differential gears (the weak one), and secondly a diff with two cross-pins carrying four differential gears (the strong one). Quite where and how the expressions "two pin" and "four pin" which are so widely bandied about come from is a mystery (it may be that the diff gears are being incorrectly referred to as pinions, hence 2 or 4, but they are not).
If on your build sheet LR is being technically accurate they may be saying both your diffs have two cross-pins and hence four differential gears, which is what we would expect. |
when we were doing lots of race boxes ( not land rover) it was called a one pin ( or standard one ) or the uprated one was called the two pin
Must admit I have always questioned the two/four pin name, as it makes no sense.
I was really pleased to see my front diff was shot, if it had been ok, I would have been questioning the boxes, and I don't want to go there ![]() Andy |
but then a 2 pin is really a 3 pin , one long pin and two short ones
