Home > Technical > Chassis repairs and rear cross member rust
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
I have been looking at a Land Rover Defender, the Chassis has been repaired. By the looks of it sections have been cut out with new metal welded back in. The rear cross member has some rust which looks like surface rust but I am not completely sure. Is it work buying a Defender with chassis repairs?
Post #348817 1st Aug 2014 4:37pm
gilarion
That is a bit like how long is a piece of string.
If the chassis repairs have been done well then it may be OK. Surface rust on a cross member is easily dealt with. I suppose it is all to do with age of the vehicle and price. If the vehicle is not that old you have to ask yourself why has the chassis rotted away and what condition is the remaining original chassis in. Remember that chassis rot from the inside as well as the outside.
Post #348818 1st Aug 2014 4:49pm
charcoal
I don't know how to tell if the repair is good, I'll put a picture here.
Post #348822 1st Aug 2014 5:03pm
gilarion
Its adeqaute but it has just been plated a good repair would have the all the rot cut back and the plate welded into the section. You have to ask yourself what is behind the plating
Post #348825 1st Aug 2014 5:11pm
charcoal
I see. I have been told to go along with a hammer and tap the chassis, if it goes through or makes a mark it's rotten. How reliable would this method be?
Post #348829 1st Aug 2014 5:29pm
g-mack
my opinion is walk away!! there are lots of good defenders for sale. unless of course this is
A . super cheap and a fixer upperer!!
B. you dont have budget for a good one!
in which case you WILL be doing ongoing repairs Thumbs Up My 109 thread
my youtube channel
Post #348834 1st Aug 2014 5:52pm
Happyoldgit
If I were in that position I'd rather buy something where I can see the rot as opposed to a patch repair with such high class welding like that. Oh and it's all very well taking a hammer to a prospective purchase - just make sure the owner is happy with you bashing away on it. Steve.
http://forums.lr4x4.com
Post #348838 1st Aug 2014 5:58pm
mikeh501
Walk away. Once you start patching it's downhill from there.
Post #348848 1st Aug 2014 6:53pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
The chassis looks like it's never had any sort of protective coating or any love, which means the rest of the car probably hasn't had any either.
Find a similar one on ebay that is immaculate of the same age, spec and mileage then deduct ~£3000 - if they are asking more then walk away..
A new galv chassis + Labour is ~£2200 so if the rest of the vehicle is okay and 2k under budget then consider it Thumbs Up
Post #348860 1st Aug 2014 7:34pm
