Home > Puma (Tdci) > Part found under the front carpets - what is it?
Naks
Hi all
While routing the GPS cable under the front passenger seat in the landy, I found this metal part under the carpets. Anyone know what it is/does, and whether I should be worried or not?
*edit: added proper pic URL
Regards,
Nakkiran
Post #29564 12th Apr 2010 8:24am
dgardel
Italy
I can't see any images..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #29566 12th Apr 2010 9:20am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Oh No Shocked Thud Your Fuffle Valve holder has become detached, I'm afraid it's terminal Naks infact you're
K Nak ered Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29573 12th Apr 2010 10:10am
Naks
K Nak ered
yaya. Rolling Eyes
Post #29574 12th Apr 2010 10:22am
willy eckerslike
Sorry Naks.................. Laughing I've no idea what it is does look like it's had a bashing. Can't think of anything internal where that could have come from. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29575 12th Apr 2010 10:28am
alantd
Can't see the image either Embarassed One that started out as a 2.4 TDCi 110 XS
Post #29581 12th Apr 2010 11:54am
Naks
how about this one:
Post #29582 12th Apr 2010 11:56am
willy eckerslike
Really looks like a valve seat out of a gate valve, but why that would be in the car I don't know, does it split by levering just under that top rim with a sharp screwdriver Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29583 12th Apr 2010 11:57am
Naks
Not sure, haven't tried. Most likely explanation is that someone working on the car left it there by mistake. Maybe even from the factory Shocked
Post #29584 12th Apr 2010 11:58am
alantd
Never seen that before. Why would it be under the carpet? Was it just loose?
Maybe something fell off the production line Laughing One that started out as a 2.4 TDCi 110 XS
Post #29585 12th Apr 2010 11:58am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Clutch release bearing, perhaps?
Intresting if it is as it should be in the bell housing and not under the carpets Laughing
Joe
NB: the truck would not be going if the release bearing is not in place!! JLS
'El Pepe Flamenco'
Post #29600 12th Apr 2010 1:42pm
Laurie
Looks well used/worn, so it's probably something that was used in the assembly of your car and got left there accidently. Someone at the factory is cursing Rolling Eyes
Post #29611 12th Apr 2010 2:10pm
Grockle
it's a warm air/cold air valve 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #29614 12th Apr 2010 2:50pm
Cibit
Must have made a hell of a bulge under the carpet. That must be 2" across. Never seen one maybe someone in solihull lost a bespoke trim tool Mr. Green 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #29616 12th Apr 2010 2:53pm
Naks
u sure about this?
Post #29617 12th Apr 2010 2:54pm
