Home > Maintenance & Modifications > My Electrical Adventure! LOTS of photos - Part 2
Page 2 of 2 <12
Tiger
What's rusting?
Bolts? You shouldn't be seeing much steel behind trim?
Post #345991 18th Jul 2014 10:27am
Jim_Bean
Didn't know about that one.
Is this it?
http://www.amazon.co.uk/Corrosion-Block-Pu...ion+grease
I'll get some ordered Thumbs Up
Post #345992 18th Jul 2014 10:28am
Jim_Bean
Tiger wrote:
What's rusting?
Inside - Behind the panels in the rear, where the speakers are. Under the floors mats, under the rear load space mats.
Outside - Rear steps, side steps, window frame, rear sliding window locks, door locks, row of unpainted rivets (110 SW), under the external capping as well as under the bonnet.
Post #345993 18th Jul 2014 10:31am
munch90
that's the stuff but in grease form , you can get it in spray can
to be honest I think your hard pushed to beat waxoyl in some places , spray it in the crack and joints then use a hairdryer (something not too hot ) let the waxoyl melt in to joints and wipe excess off , when it cools it will seal the joint and as you wipe round your get a slight coating on and around what your spraying (as neat waxoyl get be a bit thick sprayed straight on something )
looks like the rust patches you got on the pic are from drilling swarf maybe after something was added , hoover out after drilling or spray with anti rust if swarf drops to wear to cant get at it
Post #345995 18th Jul 2014 10:36am
Jim_Bean
Spray version ordered Thumbs Up
Thanks for the tip. Yep, hoovered everything we drilled. I will now be using the spray after hoovering on the rest of the install. Top advice.
Post #345997 18th Jul 2014 10:39am
munch90
main of the swarf will be from the factory
Post #345998 18th Jul 2014 10:41am
munch90
make sure you have ordered the right stuff as some suppliers call normal acf-50 corrosion block
acf is in pinkish cans
corrosion block is in blue cans and not as easy to get
Post #346000 18th Jul 2014 10:53am
g-mack
^ it aint easy to find!! still searching! My 109 thread
my youtube channel
Post #346003 18th Jul 2014 11:11am
munch90
google search it
but one I found rust stop shop or there is a porsche spares place does it
never used either of them , I got mine down in cornwall in a shop
Post #346007 18th Jul 2014 11:32am
munch90
did you find it?
Post #346095 18th Jul 2014 5:37pm
Jim_Bean
Post #346143 18th Jul 2014 9:15pm
Riyo
Scotland 2012 Defender 110 Puma 2.2 SW Santorini Black
top job there, i really like the sockets you have added for easy access to USB and the 12v in the back, i can see that coming in very handy for camping trips and the like, im wanting to do something very similar but am thinking of using a BEP VSR for the split charge, the only thing stopping me at the moment is getting my head around swapping the OEM 110ah for 2 Odyssey 1500's..i think they are 68ah each or something giving 136ah combined. it should be enough for my needs but im hoping i can have a brainwave and figure out a way of fitting more capacity without using luggage space for the batteries. Thumbs Up top job though! i also think them brackets for the fusebox look really good.
Post #346163 18th Jul 2014 10:17pm
Page 2 of 2 <12
