Home > Puma (Tdci) > Engine oil leak keeps returning
Page 2 of 2 <12
martinfiattech
I would also check for any oil leaks aroung the high pressure fuel pump joint to the timming casing and where the water pump mounting gasket joins the cylinder block.
This in turn feeds high pressure oil to the brake vacuum pump.
A good wash off my be needed to fully trace the leak. Excuse the spelling I`am better with spanners and wires.
Post #344145 9th Jul 2014 11:01pm
nickhodgson
Do you have excess crank case pressure?
I have heard of an example of a low mileage 2.4 puma that was blowing oil out of the plastic cover (in the front timing chain cover) and the fault was found to be excess crank case pressure. The engine was blowing a lot when the oil filler cap was removed with the engine running. The car had only been used on frequent short trips and it was though that this cause the rings not to seal correctly due to carbon build up. The solution at the time was a full strip down and clean but I would have tried some magic potion and a good thrashing of the motor...... 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #344431 11th Jul 2014 9:22am
EddieL
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
That describes it exactly! The car only does short trips and it was again the plastic bung / plate causing the problem. My mate at the garage also mentioned the excessive pressure when he removed the breather pipe.
Can anyone recommend a good magic potion / flush and what is a good run - motorways or just get the revs up for a certain amount of time??
Post #344565 11th Jul 2014 6:58pm
EddieL
Another thought - would the dreaded EGR add to the coking up problem?? Especially with my short trips?
Post #344568 11th Jul 2014 7:15pm
zeerover
Belgium 2007 Defender 110 Puma 2.4 SW Zermatt Silver
Injector seals gone.
Post #344622 12th Jul 2014 1:05am
EddieL
Would a failed injector seal cause back pressure? Or are you saying a potential leak from the injector seal?
Post #344631 12th Jul 2014 4:08am
miket
EddieL - did you confirm the cause of your problem?
Mike
Post #348211 29th Jul 2014 12:48pm
EddieL
It was leaking from the bung again so have sealed it back down and given the engine a good flush through and new oil. To be honest it does very short trips so I can't help feeling it may be to do with this so keeping my fingers crossed!
Ed.
Post #348311 29th Jul 2014 9:57pm
HMARR
I have a leak in my vacuum pump seal (high pressure oil spray on the underside of the bonnet on the passengers side??? ) Can anyone tell me if this is a big/expensive job to fix? Do I need to get it fixed straight away?
Post #348334 30th Jul 2014 1:55am
zeerover
Yes they do cause back pressure and oil consumption.
Post #350275 8th Aug 2014 1:17am
Mongolia
France
[img]https://www.defender2.net/gallery/albums/userpics/14958/0_200_1235_014712384.jpg[/img]
[quote="EddieL"]I have got my local garage looking at it and it doesn't seem to be vac pump as that looks clean. I would say that doesn't look like high pressure spray more one that is getting onto the various belfs and pulleys and getting chucked around. When viewed from below its all over the front axle and n/s chassis rail. When this last happened it was coming from a plastic blanking plate on the front of the engine (I would call it on the front timing chain / belt cover but my description may be wrong!) and it is looking like it may well be coming from here again???
The truck is at the garage at present so can't do photos but will update if / when this problem is resolved. As always any thoughts great fully received.
Ed.[/quote]
May be this part 3 but I dont know how it is fixed?
Post #350316 8th Aug 2014 10:39am
munch90
Ed.
if the bung has been out a couple of times , maybe the flat cover is out of shape a bit , we have had to put a small bead of sealer round the seal a few times to get them to seal
Post #350318 8th Aug 2014 10:44am
Mongolia
France
I can't include a pic.
So I think there's a leak from the cover fuel pump (LR004639) on the cover cylinder front (LR004403)
Post #350321 8th Aug 2014 10:53am
Page 2 of 2 <12
