Home > Maintenance & Modifications > Drop arm ball joint
kipperthedog
Drop arm ball joint
I need a new one of these. Now they can be had for around £6.50 on Fleabay, I presume these will be in a blue box. Has anyone fitted one this cheap , are they ok or is it necessary to spend a bit more? Steering is not somewhere you want cheap tat really!
Post #341894 30th Jun 2014 8:12pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
I fitted one in a blue box to my first defender a few years ago, the rubber boot on the top lasted less than a year before it had perished.
Post #341896 30th Jun 2014 8:25pm
shaggydog
I think they are only £20 from main dealer.
Get main dealer one also how to:
Post #341901 30th Jun 2014 8:41pm
jst
the def drop arm joint is not a great design and changing them is not the easiest job either. the disco conversion is a far better option with a std TRE,
having said that i have used Bearmach kits with good results.
Best thing to do on a vehicle you intend to keep is change the arm. Gwyn Lewis do a complete kit for it now too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #341902 30th Jun 2014 8:45pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I after loads of hassle with the defender version, I went down the discovery arm route, you end up with a conventional track rod end. To make it easier I bought a discovery steering box and drop arm then sold my defender one for the same price. Whistle Whistle 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #341915 30th Jun 2014 9:13pm
jst
OP - how did you get on? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #342896 4th Jul 2014 10:15pm
Alex1976
I swapped my Drop Arm to a Disco type using the Gwyn Lewis kit. Also swapped to HD steering bars at the same time. Made the whole steering system much firmer and took away any play. Next time I need to swap the drop arm TRE it will be simple. The TRE's are all with grease nipples so should last a long time as well.
Post #343139 6th Jul 2014 10:27am
Dave T
Good choice Thumbs Up 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #343169 6th Jul 2014 1:01pm
Clive
The last time I replaced one of these I drilled and tapped the "cover plate" (item 10 above) and fitted a grease nipple.
I gave it a quick squirt every time I greased the props - never had to replace it again Thumbs Up
Post #343186 6th Jul 2014 2:24pm
kipperthedog
Thanks Clive, that had crossed my mind too.
Post #343200 6th Jul 2014 4:58pm
barbel jim
Is this the kit your referring too James
http://www.ebay.co.uk/itm/181308130720?ssP...1423.l2649
Edit to add ebay link Embarassed
Post #343201 6th Jul 2014 5:11pm
kipperthedog
I haven't yet.....
BUT I have ordered a ball joint kit and a cup fitting/removal tool. So I will soon have the wherewithal to move it from the (longish) To-Do list to the Done list!
I think I will fit a grease nipple to the cover plate. Then I just need to get better at remembering to apply the grease gun to the Defender........... Rolling Eyes
Post #343537 7th Jul 2014 7:35pm
barbel jim
Just did mine this morning. Having read of others woes at removing the drop arm, I discovered this http://forums.lr4x4.com/index.php?showtopic=14338 (sorry if the link is against forum rules Confused ). Took me just over 2 hours to replace from start to finish Replaced with genuine LR item. Happy days Mr. Green Thumbs Up
Post #344872 13th Jul 2014 2:11pm
