![]() | Home > Puma (Tdci) > oil leak i think ? |
your dealer doesn't like warranty work on your truck ?,can you explain why 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
the service manager says it has been to heavily modified
and i thought they made there money on warranty work ?! 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
What mods have you done Steve? Surely if you've not touched the engine or drivetrain, the warranty that covers the car should be unaffected by what stuff you've bolted to the rest of your truck, if the problem is to do with the engine etc.
well the frotn diff blew up when out off roading and i replaced it myself as i thought it was my faault then i read that quite a few people have had new diffs
i put an arb in the props are differents too but the engine is standard aprt from a itg filter iv got to go near my dealer on tuesday so il pop in and ask them to have a look 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
As I see it, if you've put better stuff on than OEM then you haven't risked the integrity of the car. Mind you LR might not agree
![]() It's not your brake vacuum pump starting to fail and bleed oil down is it? Ours went and there was oil dripping from everywhere. SWMBO soiled herself. Keep us posted. |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Probably your front crank seal. I know there has been a few replaced over here.
Cheers, Tim |
