![]() | Home > Puma (Tdci) > Transfer box |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Hi Guys thanks for all the replies
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
Good you didn`t set a poll!
![]() ............................................................. Earth first. Other planets later |
Hay Mk...Its nice to know someone on here is still awake
Max Member Since: 07 Apr 2010 Location: in such a remote region, couldnt find the countries flag on the site Posts: 7 ![]() ![]() |
i got a similar problem with rattles, what did they tell you? did you get it fixed? I got transfer box and clutch replaced and rattles are still there!
![]() '79 Series III |
Max its in today i'll let you know
Well the latest with the Transfer box is it needs a new selector as all the grease has disappeared from the selector housing
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Fecket its the first sign of madness you know. Talking to yourself
JMS Member Since: 05 Mar 2010 Location: Isle of Wight Posts: 40 ![]() ![]() ![]() |
Hi Fekete,
Mine goes in tomorrow morning. I was told the same, no grease and its foooked. Do you know of any recent updates i can get em to do while its in? I got the handbreak and door seals done a few months ago under the warranty ![]() Cheers, Jay |
I don't think there is any updates as such if there is any they will do them if its running fine don't worry
![]() Cheers Karl NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Thanks Karl. I will give you an update tomorrow.
Fekete,
TX box and selector was not causing my problem it was the main gearbox selector. A common problem due to lack of grease at the time of build!!! (now replaced with a nice new one ![]() Not that i have gone far yet but all seems to be ok now. I did ask about the TX box and any known issues and the response was that they have not had any on the Puma but did recomend using low range every so often to ensure the selector does not bind. Not sure this is going to help if your problem is with the TX box but did say i would give you an update with mine. Let us know how you get on with resolving yours. Best of luck, J |
Cheers J, I've had a new gear Box and its so much smoother than the last one lets see what they can do with this T/Box now thanks for your reply
