Home > Maintenance & Modifications > Body corrosion repair
WendyTheTruck
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Hello all,
I have just managed to find a replacement Very Happy for my truck stolen back in October last year. Big Cry
It's taken a long time to find a straight one at the right price but it does have the inevitable patches of mixed metal corrosion. Granted, prevention is better than cure and I'll be following the steps in the excellent corrosion prevention thread however I'm keen to repair what I can see also. My question is, aside from replacing whole panels, what is the recommended approach to treat body corrosion of the following two types:
(i) Light corrosion bubbling under the surface such as this example next to a rivet on the body side :
(ii) More severe corrosion which has broken the surface such as this example on the rear body below the rear door (incidentally, I'm not sure this panel can be replaced as a separate piece??)
Whatever I do, I suspect I'm only really delaying replacing panels but I'm interested in the experience of the group for other medium term fixes.
Thanks in advance for your advice. Thumbs Up
Post #334399 29th May 2014 4:46pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi,
Can I ask what you did in the end?
I have a similar query, lots of little area as shown in picture 1.
I'm thinking its a question of sanding back to base Ali, then etch and paint.....
Andy
Post #344863 13th Jul 2014 1:12pm
WendyTheTruck
Hi Andy,
In short, I'm still working on it. The collected wisdom seems to be :
(a) prevention is better than cure
(b) to truly sort the problem replace the panel (not always practical or cheap) and anything else will delay the return of the corrosion but not cure it.
In cleaning up the area shown in the second picture it turns out there was a large amount of mud holding moisture against the inside of the panel which caused the problem.
I'll be booking my truck into a local LR specialist to get the repairs done then religiously following the corrosion prevention guide on this forum.
Having said that if this is the worst problem I discover with the new truck then I'll be happy!
Post #345118 14th Jul 2014 2:39pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Ken Wheelwright - renowned Series One restorer told me he used vinegar on such corrosion to get rid of it. I presume that it neutralises the oxidation? Euro-Leafing to infinity and beyond.....
Post #345320 15th Jul 2014 12:30pm
