Home > Puma (Tdci) > Help! Unleaded in tank! Replies ASAP please.
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
My business partner just called (I'm in an airport unable to help) to say he filled his Puma tank with unleaded. There was a 1/4 tank of diesel left. He then drove two miles and has now been towed to a small garage after conking out. If anyone can give him some pointers could they email phil@synergyyachting.com as he will see these on his Blackberry.
I'm hoping to hear this isn't a big issue but suspect otherwise......!
Post #28084 26th Mar 2010 9:36am
K9F
May help with a few pointers will look further: Just Googled as I have no experience with this issue but you may get route you want to go down by looking at these:
http://www.mbclub.co.uk/forums/engine/6164...t-out.html
http://passionford.com/forum/general-discu...pdate.html
http://www.techsupportforum.com/automotive...-tank.html
Complete drain and filter changes seem to be the normal route down which to travel. If you've got AA/RAC cover get them to take it home and sort it yourself. Be wary who you involve as warranty may be affected. Ultimately the route down which you travel can range from the cost of draining the tank and filters to whatever they decide to charge - be careful and good luck. Let us know how you get on! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28087 26th Mar 2010 10:08am
alantd
Call LR assist and let them sort it.
I don't think the Defender is too bad - it's the FFRR and RRS that are super-expensive I think. Maybe the D3 as well. I think they have to strip all the fuel lines out and replace Shocked One that started out as a 2.4 TDCi 110 XS
Post #28094 26th Mar 2010 10:28am
K9F
Warranty Protection!
What about warranty! It could be null and void if LR Assist becomes involved surely? Best to get it home AA/RAC if you're a member and seek further advice and /or do it yourself if you're able!
Just my opinion! Thumbs Up
Have sent e-mail direct. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28099 26th Mar 2010 10:37am
110SEB
I've done this on an Escort van. They drained the fuel tank, drained the lines and fuel filter, filled it with diesel and revved the nuts off it until the smoke cleared. It then ran fine. I too drove about 2 miles until it crept to a standstill.
This will not be covered by the warranty I don't suppose. Good luck.
Post #28101 26th Mar 2010 11:06am
dullbird
Australia 2007 Defender 110 Puma 2.4 SW Tonga Green
If I were you I wouldn't take to land rover I would have the fuel system drained and cleaned by an independent company..... YOU KNOW REHAB IS FOR QUITTERS!!!!
Post #28104 26th Mar 2010 12:22pm
mse
The AA have a van that come to the garage/side of the road and fix it for you...that has to be the way to go Mike
Post #28114 26th Mar 2010 1:36pm
110SEB
Agreed - don't tell LR.
Post #28117 26th Mar 2010 2:03pm
alantd
It shouldn't affect your warranty. When I bought my wife's FL2 they expressely told us to call LR assist if she filled it up with petrol. It was one of the LR assist services.
However, they said the cost of the fuel to sort it out wouldn't be covered by the assist package. One that started out as a 2.4 TDCi 110 XS
Post #28125 26th Mar 2010 2:32pm
K9F
On The Move Again Yet?
I reckon he should possibly be underway again now? Wonder what the resolution was?
Question If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28129 26th Mar 2010 2:45pm
Grockle
if LR find out you could end up with a restricted warranty 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #28130 26th Mar 2010 2:53pm
caribcat
OK, here's the update.
Garage pumped the tank etc etc and after a little smoking and rattling they left Devon towing 2 tonnes of RIB in a happy Puma, though one of the guys has a pretty substantial hangover and a bad case of the runs just to make things worse! Just spoken and they are on the M6 and the only problem is £$%^&@ in rep-mobiles driving like @!^%$ (their words not mine!) Other than that the Landy is pulling like a train at around 70, though the fuel gauge isn't quite so enthusiastic!
So it appears as though the engine is tough enough to take this. Thanks for all the input.
Post #28142 26th Mar 2010 5:24pm
Grockle
lets hope you've got away with it then 2.4 90 XS
Post #28149 26th Mar 2010 6:08pm
K9F
Good news! Glad it all panned out! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28159 26th Mar 2010 7:33pm
