![]() | Home > Technical > Triming a Number Plate |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
there is a regulation size , but as long it can be read ok ???
lots of bikes have smaller plates |
| Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467
I put the front reg plate on the vent flap one of my previous Defenders, as far as I recollect there needs to be a minimum of 11mm all around the outside of the letters/numbers to remain legal, so there should be room unless you have a particularly long number
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
Are right cheer's
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
| Vizsla Member Since: 18 Nov 2012 Location: Berkshire Posts: 96
11mm border is correct.
Page 9 on this has dimension details. https://www.gov.uk/government/uploads/syst...067666.pdf |
| GreigP Member Since: 13 Apr 2014 Location: aberdeenshire Posts: 18
Nice one will make sure I leave 11mm cheers, g |
There it is, plenty of room, and you can read it while wading
Click image to enlarge |
Nice one i will do that
| jhnstap Member Since: 01 Apr 2013 Location: Bournemouth Posts: 73
Got one of these fitted you may be able to adapt
http://www.bushranger.com.au/x_bar.php I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine |
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
