Home > Puma (Tdci) > Difflock drain plug and hose
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hi all,
I have just placed an order for the Difflock Drain Plug and Hose for thr Defender TDCi Puma.
I have waited a long time for this and they are now available. This makes the oil change a singe with no mess whatsever, see Difflock website for picture.
Should anyone be interested in obtaining this you can contact Justin at sales @Difflock as he hasn't yet got the catalogue number sorted yet.
Great piece of kit making oil changes from the sump almost a pleasure even without lifting the vehicle.
Thought I might inform all of this.
Joe
'El pepe flamenco' Thumbs Up JLS
'El Pepe Flamenco'
Post #27928 24th Mar 2010 3:55pm
WarPig
I put one on my 300tdi 2/3 years ago. Highly recommended, oil changes are a breeze, as you say.
They may seem a little expensive, but worth it.
Still havent mastered the art of removing oil filter without spilling oil down my arm though, even when using the carrier bag trick.
Post #27933 24th Mar 2010 5:29pm
mse
Similar story - had one for probably about 5+yrs - great things.
When i take up my own service i will get a puma one...untill then there is little point. Mike
Post #28000 25th Mar 2010 2:41pm
alantd
Do they stick out the bottom of the sump? I assume they're not that exposed. One that started out as a 2.4 TDCi 110 XS
Post #28011 25th Mar 2010 3:36pm
WarPig
They stick out only slightly more than a normal plug, but that is because of the removable cap to keep the plug clean.
Definately not exposed though
Post #28044 25th Mar 2010 8:25pm
mse
Ive never had or heard of a problem off roading with them - they also do them for other makes not just LR's Mike
Post #28071 26th Mar 2010 8:23am
alantd
Right then. Added to the list when I'm out of warranty (which is rapidly approaching Shocked ) One that started out as a 2.4 TDCi 110 XS
Post #28092 26th Mar 2010 10:23am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I've been waiting for this, especially as the Puma sump plug has the rubber gasket as part of it and therefore is a replacement item every oil change. Never bothered with the Td5 or Tdi ones as the replacement washer d.idn't cost much, but now I'll consider it 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #28178 26th Mar 2010 9:09pm
