Home > Puma (Tdci) > Turbo Hose Replaced
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Turbo Hose Replaced
My 2012 2.2 was recently at the dealers for 'routine' warranty work. They OFFERED to replace the turbo hose with a modified arrangement under warranty. This due to pulley abrasion risk. This was done today (3 hour wait in reception). Dealer said that if required turbo hoses will be replaced on 2.2's that pass through the workshop during warranty or service work.
Post #331128 14th May 2014 11:16pm
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
My hoses were also replaced during its 12000 mile service for the same reason. Assume it must be a nationwide alert. Mine is 11 months old so guess it affects quite a few 2.2's
Post #331158 15th May 2014 7:31am
K9F
It is a common fault and well documented on the forum. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #331164 15th May 2014 8:00am
Surrey Rover
Re: Turbo Hose Replaced
Count yourself lucky you didn’t discover the fault at the roadside! http://www.defender2.net/forum/topic27681....rrey+rover Nick
2.2 110 Tipper
Post #331170 15th May 2014 8:40am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
The 'modified arrangement' I believe is just just a cable tie lifting it up out of the immediate danger zone!
Post #331181 15th May 2014 9:57am
Pickles
Where is the "danger zone"?
Pickles.
Post #331183 15th May 2014 10:14am
taazzukcb
Where the turbo hose passes the belts and pulleys for the Alternator etc ..
See Jim_bean's thread (He's on his 3rd or 4th hose I think now and this time, they cable tied it up to another hose to stop it bouncing onto the pulley/belts) ...
http://www.defender2.net/forum/topic21673.html
Post #331184 15th May 2014 10:23am
stevie
The modified hose has a bracket to hold the pipe in a fixed position. I know as this is my 4th pipe and now it looks like it will last Rolling Eyes
Post #332427 20th May 2014 9:21pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Mine was done as it was rubbing on the steering column. Nice new bracket and hose fitted.
Post #332558 21st May 2014 5:01pm
