![]() | Home > Maintenance & Modifications > Koni Shock Absorbers |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
The konis are great i have them on mine atm, in std height and i have +2 konis too.
As for upgrading the springs i wouldnt unless you want to lift the car. I have run mine for 4 uears with just sts springs and koni std height dampers and found the ride to be excellant. The part numbers look to be spot on with what i have. Try flatdog or paddock spares or extreme4x4 as these were the cheapest last time i looked 2004 TD5 Defender 90 xs station wagon |
elyassi Member Since: 17 Mar 2013 Location: Abu Dhabi Posts: 17 ![]() ![]() ![]() |
I just checked with Koni dealer here in Dubai, and I came to know that these shocks is twin tube and not monotube as I thought
tdi-rick Member Since: 15 Aug 2007 Location: Oz Posts: 2 ![]() ![]() |
They are a low pressure gas twin tube, and that's a problem because ????
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
I bought mine from defenderbits:
Defender Koni Shock Absorber Front TD5 8240-1181SPX Defender TD5 Koni Shock Absorber Rear 8240-1182SPX They fitted my 110 Puma perfectly. Biggest benefit is to the rear. They made a huge improvement, the fronts less-so. If you do then one end at a time, do the rears first, you'll get a 90% improvement for 50% of the outlay... Write-up here http://www.defender2.net/forum/topic16066.html and here http://www.defender2.net/forum/topic19803.html?highlight=koni Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
