Home > Maintenance & Modifications > Aerial
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Aerial
Hiyup,
Any one have any fitting instructions or guides for fitting a replacement aerial? Someone (not me!) fell into mine drunk one night whilst parked in town snapping it. Got a replacement but never replaced one before.
W
Post #27822 23rd Mar 2010 1:03pm
K9F
Warren,
I am sat in my office and this is just a guess, someone may correct me if I'm off track.....
Me personally I reckon the best way of attacking and replacing the aerial would be to remove the blank off of your right hand wingtop to get access to the underside of it. (7 cross-head screws) It should then just be a matter of undoing the old aerial and a one for one swap out following the routing of the original coaxial cable. The radio will have to be extracted (I popped along to my local dealership and got them to unlock mine when I needed it out! Just push fit back when finished.) Obviously under dash access panels may have to be undone as required for access to aid installation. Maybe have a few tywraps to tidy up any loose ends. Hope this helps.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27833 23rd Mar 2010 3:16pm
warren
Cheers K9! Much appreciated!
I'll give it a bash this weekend if the weather is fine
W
Post #27859 23rd Mar 2010 7:55pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
The radio is a piece of cake to remove....just need a couple of small screwdrivers or allen keys, that fit into the 2 holes at either end of the radio itself. Push them into these holes, 1 end at a time (or both, if you have enough tools), then gently push them both outwards, but at same time, pulling. Keep repeating this at either end in turn, gently pulling until you can get a grip on the radio body to slide it out fully.
Failing that, nip to Halfords and buy a pair of radio removal tools, which does make life a little easier....
like these:
http://www.halfords.com/webapp/wcs/stores/...yId_165626
HTH Wink Mark
2011 110 XS DC
Stornoway Grey
Post #27863 23rd Mar 2010 8:43pm
warren
Aha!!
Think I have a couple of those lying around from when I took the stereo out of my old Astra. I'll have a rummage and find them again.
Ta Thumbs Up
Post #27874 23rd Mar 2010 11:04pm
RED-DOT
Cut the coaxial at the base of your old ariel and attatch a metre length of string to the cut end and cover in insulating tape so it doesn't snag. Pull it until it appears at the radio then attach new coaxial cable the same way with insulating tape and pull until it appears at the radio end. This saves stripping the dash out.... HTH? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #27879 23rd Mar 2010 11:38pm
alantd
Good tip! That would certainly save a lot of bu**ering about Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #27886 24th Mar 2010 12:02am
RED-DOT
Took 15 minutes on my old TD5 and a dash out job takes 2 hours minimum and i would go for a better ariel than the rubbish L/R one... possibly a "rubber duck" or a removeable and unbreakable one. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #27888 24th Mar 2010 12:08am
chopdogs
Hi - this may help
http://www.defender2.net/forum/topic3984.html?highlight=aerial
Worked a treat for me.
I used some long nosed pliers to turn the top circular piece of the aerial to get it off, cut the cable, attached the female connector, plugged in the new aerial and used the pliers to tighten it all back up onto the wing. Took about 10 minutes.
I got the female connector off ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...0470455608
Hope that this helps
Post #64841 23rd Mar 2011 10:52am
