Home > Wheels & Tyres > Tyre Widths - What difference does it make?
Page 1 of 4 1234>
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
I've recently bought a Defender and very pleased so far Very Happy
It has 235/85 AT tyres on heavy duty Wolf rims - which seem to do a good job both on and off road (green laning).
In the near future I want to get some muds, probably as a second set/ mayby the only set.
Everyone seems to go for the widest tyres possible up to 265 or even 285's with standard suspension.
The question is:
What difference do wider tyres makes in reality or is it just for looks?
Come on all you knowledgeable folks Bow down
Steve. Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #27761 22nd Mar 2010 9:54pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
well i run kumho kl71s that are over a foot wide for the road and there a mud teraine and there useless in the mud they go like slicks and i run 10.50 wide tyres when off roading but they are simex but there is no comparison narower tyres will always cut through mud better
in my opinion
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #27765 22nd Mar 2010 10:11pm
fekete
Wide tires offer looks which many people like. Beyond looks, wide tires are used where flotation and stability is desired. Narrow tires are used where traction, primarily in muddy conditions, is desired. Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #27767 22nd Mar 2010 10:19pm
Laurie
...and it affects your steering lock.
Post #27768 22nd Mar 2010 10:20pm
...Unless you've got wheel spacers or wide offset rims.
trouble is, big wide tyres make the side of your truck look like a mud pond the first puddle you go through. I used to have 35's on my 90... I could never see to the left or right unless it was dry terrain.
255/85's are an ideal size. slightly wider than a 235, but not silly wide, and a bit taller, but not in the realms of 35" territory, but enough to give you an advantage off road.
They handle well on the road too.
Post #27773 22nd Mar 2010 10:34pm
alantd
<pssssst> That's the sound of you opening a can of worms Very Happy
As above: Wide = flotation (good for sand and deep snow). Narrow = sinking in and possibly finding some traction lower down.
Wide (285 and above) will reduce your steering lock so you'd need spacers. You'll also put more strain on your half shafts and general drivetrain. Some folks have never had a problem and they look pretty aggressive if that's what you're after.
Narrower (265 and below) will probably suit what you're doing better, however. 235, 255 and 265 are probably your best bet. If you've got 235s already then try a set of 265. That'll give you a bit more width for the look and flotation for softer stuff (not tearing up fields) but still give you some bite in the gloop. You can also fit 265s to standard 7" wheels. One that started out as a 2.4 TDCi 110 XS
Post #27782 22nd Mar 2010 10:55pm
K9F
alantd wrote:
<pssssst> That's the sound of you opening a can of worms Very Happy will reduce your steering lock so you'd need spacers. You'll also put more strain on your half shafts and general drivetrain.
Atlantd agree 100% about the can o' worms.....
I am indeed no expert and the following is based on opinion and as such I may be wrong and apologise in advance....
The sun is shining and I do not wish to appear objectional or argue with anyone today....Atlantd I have no axe to grind and wish to offer my hand in friendship and not antagonise you in any way, shape or form....
Very Happy Very Happy Very Happy Very Happy
Here goes Thumbs Up Thumbs Up ....
Steering lock may not be affected at all dependant on wheel offset.... as with spacers they too may not be needed dependant on offset....With regards to half shaft and drivetrain strain surely this is dependant on exactly how much of your wide tyre is in hard 'road/ground contact?' As with motorcycle tyres (ideal example) you can have a really wide tyre but only a small percentage has contact with the road due to the oval profile of the tyre?....My Coopers are an ideal example as I would say that they have less hard road/ground contact than standard tyres and thus possibly less strain/friction upon drivetrain/half shafts than normal OEM tyre fitment maybe....
I put wider wheels/tyres on unashamedly to obtain 'the look' I was after....Because I can... and am more than happy with the end result....MOT inspector may have a different view however....We shall see in a little over 14 months time....
Just added this bit after posting.....Does a bigger offset cause extra drivetrain/half shaft strain due to the 'stance' of the vehicle and downward load bearing? I think I may see your point Atlantd....
Let peace and tranquility prevail.....
Struggle....Struggle....Need to get lid back on I think... Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27796 23rd Mar 2010 9:44am
alantd
What!?!! I'm outraged Evil or Very Mad
How could you?! Banging Head Grrrrr Rant rant Grrrrrrr
Oh, hang on - you're probably right Very Happy
The sun is trying hard to shine in London, my cargo barrier is fixed and all's well with the world Thumbs Up
I never take offense - even when it's intended - and usually I'm wrong so I've learned the value of respecting other people's opinion. One that started out as a 2.4 TDCi 110 XS
Post #27800 23rd Mar 2010 10:07am
K9F
Banging Head Banging Head
Atlantd excellent retort, clearly defined, well presented and finely executed! Wot no fighting????
Thud Thud
Off Topic Happy days - Clocks go forward this weekend yippee! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27801 23rd Mar 2010 10:16am
So Iam now gettingup at 03:00 Merd Merd
Post #27802 23rd Mar 2010 10:22am
K9F
Ken,
You'll be hitting the pit an hour earlier though to offset the width of your day! A good night's kip will prevent you from looking wheely spaced out! ON topic and on cue I think!
Rolling with laughter Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27804 23rd Mar 2010 10:51am
jst
235.85s (31" high) work well with a std vehicle, if you dont do alot of towing or hilly work then 255.85s (33" high) you will get away with no problem.
265.75s = same height as a 235.85s - better on road handling but not so good in the gloop as described above as quite wide.
For UK conditions 235s or 255s have always worked well for me less competitions.
If you go wider than IIRC 265 it wont go on a std LR rim rim which means you also need offset rims or spacers to maintain the steering lock or live with less lock.
Moving the wheel further out from the stub will put more strain on bearings. CVs if the lock is the same wont be affected through the angle, but the shock loading if off road and suddenly stopping is increased with bigger diameter tyres over stock.
i run 235.85s Tracedge on my 110
255.85 MTs on my truck cab
265.75 ATS on our training vehicle.
plus have a set of 35.10.50.16 Fedimas for comps Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #27809 23rd Mar 2010 11:11am
Cibit
And I thought your indecipherable posts where cause you where Censored Rolling with laughter
I get up at 04.30 but the upside is you get afternoons to write drivel on forums and watch movies Thumbs Up
Bow down Rolling with laughter 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #27839 23rd Mar 2010 3:41pm
K9F wrote:
Ken,
Nah it will be lighter so more fitting toy time Thumbs Up
Post #27841 23rd Mar 2010 4:10pm
K9F
Ken,
Wot Lights at £1000 a pair???? Next time you go on a bank raid take me with...... Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #27842 23rd Mar 2010 4:15pm
Page 1 of 4 1234>
