Home > Technical > Alternator ?
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Alternator ?
Hi guys
Is it possible to fit / make a disco 200tdi alternator fit a defender 200tdi as I want an 100 amp alternator and the only ones I can see are for disco's Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #329265 8th May 2014 1:17pm
On a 200tdi,i'm sure the only difference is the main battery cable.
large spade connector vs. bolt on ring.
if the mounting lugs are in the "wrong" place you just unbolt the long thin bolts that hold both halves of the unit together then rotate it around.
But I think the disco unit is just bolt on. (although its been years since i changed one)
Post #329296 8th May 2014 2:49pm
