![]() | Home > Puma (Tdci) > Diff Guard from Masai |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
1. These diffs don't break easily, so don't worry!
2. There are 2 types of rear axles out there, you may have the other one. Maybe take a picture of it, I'm sure someone can tell you what type it is. 3. You can always sell it on, or maybe they'll take it back. 4. There are other brands like QT, D44 etc which are top quality as well. |
Pic of the diff might help identify it?
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
Thanks guys. I will try and post a picture once Ive got one. Cheers.
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Do you have a 110? If so the 110 rear diff is larger than the one on the rear of a 90. Ask me how I know
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17929 ![]() ![]() ![]() |
90 has Rover pattern diffs front and rear.
110 and 130 have a Rover pattern diff at the front and a P38 diff at the rear. Rover pattern and P38 diffs are completely different. |
Yes I do have a 110. Would have expected Masai to tell me this as they knew I had a 110 as I also ordered the panramic glass and rear quarters along with the diff guards ![]() |
Sign of the times. People just do and don't think anymore.
If you have a car issue your dealer plugs it in and replaces everything the computer says that has a bad reading. They fix the symptoms not the cause. Know a guy who had 3 turbos replaced, in the end it was a hose that kept collapsing under to vacuum. Bill went up to 15000 euros. Needless to say it is a courtbattle now. |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Yup, but I'd be interested to know where the casing style comes from? Because the later p38 style, unless I just need to go to specsavers looks bizarrely very similar to the front one, and yet holds twice as much oil... ![]() |
