![]() | Home > Technical > Leaking wheel cylinder |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
The drum brake parts available now are sadly rubbish no matter what make you buy. Sad but true. Best long term fix is to convert to discs.
Had to do my H reg 90 a few years ago as I got sick to death of playing drum brakes every few months. |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
aluminium cylinders don't last as long as the older cast iron ones
take it he has tried greasing the cylinder with RUBBER grease when fitting |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
The disc brake idea has been floated but the issue there is the Spanish ITV might not allow it.
I think he has greased the rubber when fitting. But why only one side leaking? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
excessive play in wheel bearing?
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Silly question [or maybe not] but is the vehicle regularly parked for periods on a side slope? Reason for asking is that I had drum braked vehicle that, despite several replacement cylinders, leaked from one side but it only did it when parked for longish periods at a certain angle.
Never did get to the bottom of why it did it Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
My mate has just informed me that the issue has re-appeared again on the same side of the car/same wheel.
He is now pondering the option if replacing the master cylinder/servo to try and solve the issue. Any more thoughts would be most welcome 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| All times are GMT |
