Home > Puma (Tdci) > Rise in revs Puma 2008
ARC99
I know that this has been covered and someone posted a section of the wiring diagram..
Due to ongoing health problems I'm having problems locating the thread. Can someone help me out please. Don't make old people mad.
Richard
Post #328599 5th May 2014 8:28pm
bob neville
Hi Richard
Are you referring to the revs rising when you depress the clutch ?
If so, this could be the problem with the fuse blown on the brake lights or both brake light bulbs blowing.
I will see if I can find my original post on this.
Edit. Here is my post from 2012. I am sure there is another explaining why !
http://www.defender2.net/forum/topic11644.html?highlight=brake
2013 Defender 90 CSW - sold
Post #328603 5th May 2014 8:53pm
K9F
Here's some more information on this.....
http://www.defender2.net/forum/topic24009.html?highlight=revs
http://www.defender2.net/forum/topic22317.html?highlight=revs
http://www.defender2.net/forum/topic4298.html?highlight=revs If you go through life with your head in the sand....all people will see is an ar5e!!
Post #328633 5th May 2014 10:43pm
ARC99
Thanks for the help, I think it was the bit from Bells Auto I was look for. Thumbs Up
Yes it was the rise in revs between gears when clutch pedal depressed. Don't make old people mad.
Richard
Post #328703 6th May 2014 1:37pm
K9F
You're welcome. Hopefully between the links it will sort any rev rises your truck is experiencing.
Hope you too are on the mend! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #328707 6th May 2014 1:41pm
ARC99
Well the plot thickens.
The Land Rover has been to my local independent who was certain he had the answer after doing his research.
Clutch sensor working fine, fuse, and cable and brake light all OK. but it still does it. Don't make old people mad.
Richard
Post #329834 10th May 2014 9:48am
landy andy
Do the revs rise. Or does it hold its revs? If holding its revs between gear changes I thought this was normal for moden engines.
Andy
Post #329858 10th May 2014 11:39am
ARC99
The Land Rover independent I use believes that it is not normal as they have never come across it before and it frightened the owner and mechanics when they drove it, the revs went up by 750 rpm. Don't make old people mad.
Richard
Post #329868 10th May 2014 12:02pm
bob neville
This is a long shot but ....
Do you have towing electrics connected up ? As we know that problems with the brake light circuit does cause the problem it is possible that a fault in the towing electrics could cause it as well.
If you do have towing electrics it should just be a case of pulling the plug in the rear offside wheel arch behind the plastic panel to eliminate that as the issue.
It sounds like the indy has checked all the normal suspects.
Post #329885 10th May 2014 1:50pm
