Home > Maintenance & Modifications > Hiding wires in headlining
kmac
Need to install some wiring in headlining for a dash cam to be located behind the interior rear view mirror
Tried to search for this but only came up with
http://www.defender2.net/forum/topic25175....ing+mirror
Which doesn't mention how hard it is to loosed the headlining, add a cable and put it back nicely taut
Anyone done this and any top tips?
Post #328267 4th May 2014 12:32pm
VeeTee
Netherlands
Yes, it isn't difficult. Did it some weeks ago to extend the wires from the interior light to fit a map reading light.
Just remove the rear view mirror and its bracket, and the sunvisors. Then you can pull the headlining a bit down to hide the cable. Cheers, Vincent
MySite
Post #328268 4th May 2014 12:37pm
kmac
Ok will give it a go right away
Edit: Job done, easy as you said
Post #328269 4th May 2014 12:41pm
VeeTee
Netherlands
Thats quick!
Cheers Thumbs Up Cheers, Vincent
MySite
Post #328276 4th May 2014 2:20pm
