Home > For Sale & Wanted > [Wanted] Defender 2.4 AirCon fan |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2725 |
Is the electric aircon fan an easy swap over?
Mine makes a sound like that of a movie exorcism, or perhaps a jet engine. Also where would i find one? struggled to find one on ebay/google etc. Anyone have the part number cheers Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
28th Apr 2014 11:24pm |
i just need the electric fan that sits right on the front, do you have that?
can you see if its easy to remove? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th Apr 2014 10:43am |
S3dxm Member Since: 17 Aug 2013 Location: York Posts: 82 |
I have just found it in the deepest depths in the back of my lock up...
Knew I had it somewhere.... I shall put a battery to it and make sure all is good. Looks simple to remove with 4 m6 bolts holding it in position. I will update my findings later this afternoon. Click image to enlarge 2006 110 CSW Td5 2004 D3 HSE 1992 200Tdi 90 project 1975 SWB S3 even bigger project |
29th Apr 2014 4:27pm |
yeah looks the right thing but at uni atm so can't check. If its from a 2.4 itt must be right.
what would you want for it providing it works ok? mine currently sounds like a busted extractor fan, its horrible! edit: just noticed your 110 is a td5, is this fan correct for a 2.4? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th Apr 2014 6:34pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
Fan is the same, I believe. Shout if it don't work out
Andy |
29th Apr 2014 8:35pm |
S3dxm I'll take it then if the price is right Cheers, David
29th Apr 2014 9:16pm |
Apologies,
Got side tracked somewhat last night. I'll get the fan removed today and tested, and let you know. 2006 110 CSW Td5 2004 D3 HSE 1992 200Tdi 90 project 1975 SWB S3 even bigger project |
30th Apr 2014 5:52am |
It's no problem, thanks again for making the effort.. Cheers, David
30th Apr 2014 10:00am |
Hello again!
Made progress. Fan removed and tested. All in good working order. Let me know if you would like it. £25 PayPal as a gift and I will get it in the post today. Cheers. Dan. Click image to enlarge 2006 110 CSW Td5 2004 D3 HSE 1992 200Tdi 90 project 1975 SWB S3 even bigger project |
30th Apr 2014 2:26pm |
pm will be sent within seconds Cheers, David
30th Apr 2014 3:40pm |
Replied and all sorted! 2006 110 CSW Td5
30th Apr 2014 3:50pm |
