![]() | Home > Puma (Tdci) > Bonnet insulator |
| Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266
I think Noise killer do a pre cut one on their website. Not tried it personally but I've heard it's good providing it stays dry. 2007 (57) Defender 90 (Sold)
Looking for another to replace it. The road less travelled.... is a muddy one! |
| Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735
Cheers Josh. Now I've insulated and carpeted the back of the truck, the noise from under the bonnet seems to be more apparent. It doesn't bother me, but I thought if there is one out there I might fit it.
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141
I have fitted a Noise Killer Puma bonnet kit but I am not sure its makes a great deal of difference as it only cover the panels in between the strengtheners so there is still a lot of the bonnet that is not covered.
I am thinking if investing in their lead engine blanket which i am told is good for reducing engine noise. |
| Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233
You are better off to get the underside of the bonnet sound deadened with Skinz or a similar non flammable product. It also makes it much heavier if some scumbag nicks it.
That's a good idea
Out of interest, is it normal if you look around the bonnet edge when it is closed, to still be able to see engine hoses, components and the bonnet catch through a huge gap?
The sides of my bonnet are close to the wings but there is a gap at the front of about 10mm
Well I'd say there is a full 1cm gay at the sides of mine, and more like 2 cm at the front!
Gap not gay!
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
10mm thick, latex backed felt, glued an cable tied to the underside of my bonnet and yeah, I can check the dipstick thru the gaps around my bonnet
You may have to cut a small hole in the felt where the brake m/c reservoir cap is,depending on who fitted your bonnet at the factory,lol. http://www.frost.co.uk/sound-deadening-felt-sheets.html Pov.spec,ftw. 2006, 110,TD5. |
