![]() | Home > Maintenance & Modifications > Tow hitch bolts |
if your on about the six holes you can see under the spare wheel & above the centre of the step
not 100% on this without going to look ( I will go have a look for you ) but I think they have to be longer than 30mm as the threaded part is behind cross member , so the bolts go right through so 30mm wont be long enough |
IGNORE ME!!! , YES THINK 30MM ARE LONG ENOUGH
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
They should be standard pitch M16, not fine pitch.
. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
because they a structural bolt are they fine pitch , think they maybe are (say again I think not 100% sure )
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
As stated above they are an M16 ISO Standard coarse series thread, 2mm pitch, not fine series (1.5mm pitch). You have the wrong thread. Grade 8.8 is entirely adequate, but socket head capscrews will be 10.9 unless otherwise specified.
garryforrestuk Member Since: 01 Nov 2013 Location: north east Posts: 27 ![]() ![]() ![]() |
Thank you all for the help need coarse thread not fine thread. My mistake Garry
