![]() | Home > Technical > Stupid question - jacking the rear |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Nobody know if this alright then?
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
No problem.
Don't forget it's off centre so your Landy will have a port list. ![]() |
| charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211
I usually lift it from the sway bar under the diff and then place a axle stand on it before removing the wheels. Then have the trolley jack under the main section of the diff
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
It cost me a lot of money the first and only time I used the diff as a jacking point.
We don't like being old in the first place, so it doesn't take much to Richard |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Why, what happened? Darren
Will it wasn't on a Land Rover, it was on a friends vintage car and after getting the wheels off the ground the oil started to flow. twelve months of apprentice wages to pay for new diff casing. Don't make old people mad.
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
saw them moving a 110 in the factory from the rear diff with a FLT attachment made for the job DEFENDER 90 TDCI XS,
Ah, ok. Not really relevant here though, as a LR diff is a recognised jacking point. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
wow... no answer in 21 minutes and you were throwing your toys out of the pram! |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
sealey do a jack adaptor for lifting with off centre diff so lifts straight
More based on the amount of people that had read it in that time and neither confirmed or denied it meaning it wasn't as obvious/well known/ daft question as I thought.
But thanks for pointing that out and the I'll go pick my toys up. |
I certainly am
