Home > Wheels & Tyres > Wobble |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Fitting Discovery rims on a Defender may require the use of hubcentric rings (spigot adapter rings). Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
2nd Apr 2014 8:27pm |
Which type of Disco rims? They should be a straight swap and not require spigot rings. Darren
2nd Apr 2014 9:23pm |
The Monkey Member Since: 11 Aug 2013 Location: Meath Posts: 63 |
Discovery stealies man nothing fancy
2nd Apr 2014 10:10pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
The hunk of junk jimny I am forced to drive as a daily suffers from the same. Done all sorts of things to make it better and it turns out that 2 of the tyres are not round. With them on the front it is almost impossible to drive yet on the back it is not far off right. Might be worth checking your own for being round too? Rhubarb and custard let fly with their secret weapon.
3rd Apr 2014 5:39am |
jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112 |
I had similar issue with AT's, at about 60mph you would notice a vibration. Swapping them round improved but never got rid of the problem. The tyre fitter advised they were difficult to balance. I lived with it. I recently replaced the AT's with Yokohama's on the same rims and the vibration has gone. Paul
Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
3rd Apr 2014 8:32am |
Steel Disco rims are very strong and a straight fit on Defenders. It's far more likely to be the tyres as other have suggested. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
3rd Apr 2014 8:49am |
there is a notice on autodata for this on the jimny there was trouble with lower arm bushes going or just to soft there are modified bushes to be fitted . |
3rd Apr 2014 10:19am |
Got sorted today swapped the wheels around a couple of times and found a perfect combo...
3rd Apr 2014 3:49pm |
Supposedly mine is new enough to have the fix from the factory allegedly. Rhubarb and custard let fly with their secret weapon. |
3rd Apr 2014 4:47pm |
