![]() | Home > Puma (Tdci) > Gearbox oil on 2008 |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Sounds like it had the wrong oil in it. I put red ATF in my discovery auto gearbox, certainly not a manual. If it feels better you should be ok. 130 crew cab
98 V8 Disco |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Just done my 2011 that was clean and red as well (only 11k miles) , I would not worry it is probably just the brand Land Rover use at the factory DEFENDER 90 TDCI XS,
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285 ![]() ![]() ![]() |
I also had this and questioned the garage that had put it in and they confirmed it was the correct oil and they had questioned the supplier when it arrived as they thought it was incorrect. 2008 Defender 110 XS CSW
Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
It used to be so simple changing oils but these days with the choices available you obviously can't judge by the colour any more.
![]() 98 V8 Disco |
