Home > Maintenance & Modifications > LED Brake Lights
Mech
LED Brake Lights
Hey Folks.
If I only fit new LED Brake/Tail lights to my TDI, then do I need to swap the flasher unit? I don't intend on fitting new indicators.
Post #320022 29th Mar 2014 3:38pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I don't believe so. I just put in led brake light bulbs in and they were awful. There was not enough difference between the tail lights and brake lights to tell when they where on. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #320023 29th Mar 2014 3:45pm
You want RDX led lights, and no relay needed for just the brake lights, or sidelights for that matter.
Only need the relay for indicators. Thumbs Up
They are brighter and safer.
Post #320033 29th Mar 2014 5:29pm
Mech
Already bought the Wipac Units. Seem to be of good quality. Installed this afternoon and lookin sharp.
Post #320043 29th Mar 2014 6:22pm
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
As long as you're not putting LED bulbs into filament holders you're fine. All about type approval etc.
COULD be MOT failure and or something for PC Plod. all to do with the mouldings on the inside of the lens designed to reflect light as certain angles, and LED are different light patterns to filament ya de ya.
Post #320118 29th Mar 2014 10:12pm
I have LED fixtures in my side repeaters, they work really well but I was sort of half and half as the lense is E marked.
Same with the number plate light with LED fixtures in as recently sold on here.
Although I love the LED's and they work perfectly and IMO better and brighter after reading your post much as I'd dislike to I'm starting to think I should put bulbs back in..
Why has no one ever designed an LED specific side repeaters?
E marked LED specific number plate lights are awful quality.
Seems that the law prefers conventional lighting even if there is a new improvement.
Silly really.
Post #320119 29th Mar 2014 10:22pm
Mech
These are the units I went with. I'll let ya know if they sh*t the bed.
http://www.brookwell.co.uk/wp-content/uplo...523LED.jpg
Post #320178 30th Mar 2014 10:01am
landybehr
Same with the number plate light with LED fixtures in as recently sold on here....
As for the number plate light there is a complete replacement (Sealed housing) which works very well. Looks exactly like the original, is e-marked and bright. Only the white light colour is different and needs getting used to - but that only applies to the driver following me Smile.
There really seems to be no replacement LED unit for the side flashers. Isnīt there a market for them ? Maybe you have to have a adjustable flasher relais for them which not everybody has. I have put LED-"bulbs" in them but am not really happy with these.
Post #320394 30th Mar 2014 10:20pm
Side repeaters in LED work with standard indicators I find perfectly well. No galah issues either.
And there would indeed be a market for LED side repeaters I think.
I have these type LED bulbs in mine:
http://www.ebay.co.uk/itm/2-x-5-SMD-LED-50...3a8da7c5fd
They work very well.
When I had a mobile centre LED number plate light it failed within the same day, hence getting rid and going for LED fixtures.
Plus it had regular LEDs not SMD's which are much better
Post #320395 30th Mar 2014 10:26pm
Green Machine
Am I missing something? You can get direct replacement LED indicators (Wipac, RDX etc.), I've got them fitted to mine. Oh - are you talking about the wing-mounted side repeaters? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #320403 30th Mar 2014 10:52pm
Side repeaters only. Thumbs Up
Post #320404 30th Mar 2014 11:04pm
