![]() | Home > Puma (Tdci) > Carpets V No Carpets |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
Mine came with no carpets my13 , just the tin . I'm sure with the carpet option you do not get underlay
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
About the same I'd have though noise suppression wise.
All down to personal preference really IMO vs. practicality and your intended use. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 ![]() ![]() ![]() |
A non carpet truck has no covering in the rear except a thin rubber mat in between the wheel arches; it is simply a painted arch. In the front the foot well and seat box is lined with 2mm thick semi ridged matting, that sits directly on the floor.
The carpet covers both the boot floor and arches, adding protection. The carpet is fairly thick, backed with a soft non slip rubber. In the front you have a covering over the seat box and foot well, with tailored removable mats. Some pieces are easily removed, others less so. I would say carpet makes a slight difference when driving in wet conditions, but makes little difference to the gun shot sound when a pebble hits the arch! I would spec carpet if it's a daily... I did and impressed with the fit |
Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735 ![]() ![]() |
Thinking of getting a used one which doesn't have carpets and I'm worried it might feel a lot more utilitarian (than it already does with them) as a result.
Can you retro fit a carpet set? Anyone done it? |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Depends if you use your defender for work, then carpets are stupid they just get wet dirty and smell. I am fitting the dyamat stuff for sound proofing. Since picking mine up five people have said "that's good no carpets" which had surprised me. You get a vinyl type flooring, which is easy to clean.
If the defender is just used as a car carpets help with sound proofing and temperature. So I'd say it depends on the use of the defender. |
It'll be used like a car
I think csk does carpet set. Also they come up on eBay. Also Exmoor trim.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6025 ![]() ![]() |
Csk just brought carpets from main dealer and removed his vinyl floor as carpets are only sold as an extra now. Think he paid about £100 a piece.
I'm just about to remove my carpets and fit Wright off road sound mat. Best of both worlds to me. Quietest and easy clean. Andy |
If it's a road driver only and no dogs then carpet.
Possibility of mud very wet areas dogs, kids etc the. Think about rubber. Complete personal choice though. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 ![]() ![]() ![]() |
I can confirm that carpets are excellent for making sure that all the rainwater that gets in stays in.
They seem to help make ideal conditions for the moss that starts growing on the window seals. 2009 110 XS Station Wagon |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
Another vote fer vinyl,fer no other reason than its easy to dry out....drying out is important inna Defender
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 256 ![]() ![]() ![]() |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 ![]() ![]() |
I've owned both carpeted XS 90 and the current spec no carpet XS 110 CSWs... No carpet is great, full of mud last weekend no hesitation with the hose inside! Would not have done that with carpets!
BUT, as an example the box section below the front seats is completely un covered in front of the second row seats... And therefore the kids rest their feet on the bare paint, scuff it getting in and out... Looks crap already so not happy... Carpeted version covers all these bits... Standard LR tow strop comes with a Velcro strip on the bag so that it stays put on carpet, now it slides around sat on the rear wheel box sections.... I'm seriously thinking of going back to carpet via an Exmoor Trim carpet set... Horses for courses! Matt |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733 ![]() ![]() |
The 90 I just bought from csk had carpets in the front and I wanted rubber flooring so he swapped it over while I was there. with the seats out it took 15-20 minutes to swap over.
The Rubber is much more practical for me. I cant say about the noise as its all sound proofed underneath, but hasn't made a difference I can hear. All I can say though was swapping it over looked an easy process which im sure would be easy to do yourself (might take longer as remember Chris does it all the time) Defender puma dormobile camper |
