Home > Maintenance & Modifications > I'm struggling with the most basic stuff...
Caterham
I didn't want to type this in fear of looking like a completely useless muppet....
How do you take the drain plug and fill plug out the diff?
I presume it's not a reverse thread?
And if they're a bit stiff any warnings on damaging anything (other than myself) ?
Post #319009 25th Mar 2014 4:40pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Just a normal thread. Be sure to do the filler first then you can get fluid back in. Rhubarb and custard let fly with their secret weapon.
Post #319010 25th Mar 2014 4:46pm
Caterham
Thanks mate.....
Ruddy eyes almost popped out.
Flamin king Kong must dun them up!
I need to go and sit down......
Strange undid the fill first and loads of oil came out....and no I wasn't standing on my head Laughing
Post #319013 25th Mar 2014 5:05pm
g-mack
its usually about having the right tools! in your case a decent breaker bar!. i remeber a few year ago trying to undo some radius arm bolts. had a 2ft breaker bar tried everything!! couldnt shift them. my mate then showed up with a 3 ft bar and they came off easy!!! My 109 thread
my youtube channel
Post #319019 25th Mar 2014 5:31pm
Caterham
W Rolling with laughter
A breaker bar........ Laughing
I thought you were having a laugh.
Job done thanks.......will be trying transfer box soon Shocked
Post #319030 25th Mar 2014 6:01pm
Be really careful not to overfill - check the manual
Post #319037 25th Mar 2014 6:30pm
Cupboard
It's because they're used for breaking sockets Very Happy
Post #319069 25th Mar 2014 8:06pm
Caterham
Bpman.....
As you can see the diff was overfilled....
What issues are limited to arise?
I've just refilled to fill point which I believe is circa 1.8ish ltrs and therefore more than the 1.6 Ltr mentioned in handbook... should I be worried?
Post #319072 25th Mar 2014 8:08pm
munch90
it's a level plug ,fill it till just starts to run out .same for transfer box and other axle , hubs
hubs will proberly have grease in then
only the gearbox has to have the right amount ( not to plug level )
Post #319092 25th Mar 2014 8:43pm
Caterham
I feel I may have to put my hand up to being a complete imberseal.
Have moaned and moaned about my engine i've now done a few hundred miles since new turbo And the Knocking / clatter noise is almost certainly the transmission.....hence I'm on the case of changing the fluids as a starting point but I worry it the clutch or gearbox extension AGAIN Crying or Very sad
Post #319107 25th Mar 2014 9:01pm
landy andy
Have you changed front diff oil yet?
Andy
Post #319112 25th Mar 2014 9:05pm
munch90
so your saying that the garages you took it to many times could not tell you it was gearbox issue and not engine , maybe time to look for a proper garage and not fitters
Post #319116 25th Mar 2014 9:08pm
Caterham
Yep. Done tonight Thumbs Up
Ignoring the poor performance in my biceps it was an easy job
Post #319117 25th Mar 2014 9:08pm
Caterham
Munch90....hadnt thought of it like that Very Happy
Post #319119 25th Mar 2014 9:14pm
LR90XS2011
Has Lorryman had a chance to look at it yet? DEFENDER 90 TDCI XS,
Post #319189 26th Mar 2014 6:40am
