![]() | Home > My Defender > Fuse box wiring |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Without going into too much detail jumpleads are rated at 100 amps. Bearing in mind it is highly unlikely you will draw the maximum at any one given point and taking 'diversity' (not the Dance Troupe) into account a cable with a 10mm2 cross sectional area will suffice, maybe even 6mm2. If you go through life with your head in the sand....all people will see is an ar5e!!
| Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233
You need to work out the maximum current you are going to run from this fuse box. I recently fitted an Iron Goat dash to a Defender but left the fuse box in the battery compartment. This car had 4 x roof lights, heated seats etc, most of the dash wiring is very low current, gauges, stereo, etc. If you mount the fuse box behind the dashboard make sure you fit a suitable sized fuse as near to the battery as possible on the live wire.
