![]() | Home > Puma (Tdci) > P38 pattern diff overhaul |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2493 ![]() ![]() ![]() |
I just did mine couple of weeks ago (Rear ARB and front trutrac). If you did not change the P&R, then you should not worry about the pinion height. As for pinion preload, it should turn at a 10Nm ish. Anyway, if you are interested send me a pm and IŽll send you a pdf file. Puma 110" SW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17933 ![]() ![]() ![]() |
I was planning to renew (or at least inspect) the pinion bearings while I was at it. I believe the P38 uses shims for pinion height and a crush tube for preload, but was hoping for data. Apart from this it is all plain sailing.
If need be I'll leave the pinion alone and hope for the best. |
yes, it uses 64mm diameter shims for height and a spacer (not crushable at least on mine) for preload. If new bearings are not exactly the same as before you might have problems with preload. In my case I used a 0.2mm shim for getting a proper preload. The right way should have been to use a 0.2mm longer spacer but I could not get one. Puma 110" SW
Thanks. As long as it doesn't use a crush tube (horrible bodgy things) it should be ok.
Bearings are generally made to very fine (and graded) tolerances so existing shims etc shouldn't be far out. Thanks again for your help. P38 diff info seems hard to find. |
If it is for your 110 " Puma I have the info but I need you email to send it. Puma 110" SW
I have sent you a pm. Thanks.
