![]() | Home > Technical > Door lock gubbins - broken |
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
The drivers door lock came out when I undone it and went to take the key out, atm I have to go through the back door to unlock either front door but when I am ready I will replace all the locks as both front door locks are very stiff
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455
Hi,
I soon realised that the bit that broke comes as part of the exterior handle but aren't expensive at all. I'd recommend you change them all sooner rather than later as it's easy and cheap to do. Getting in the back is a right pain in the backside and would do my head in! Dave |
| 110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158
The part I think your on about like a plastic cam you cant buy separate it comes with the handle
