Home > Puma (Tdci) > Bending Column Switch Stalk
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
Has anyone successfully done this?
I want to mount my phone on the angled surface of the dashboard behind the left hand stalk and there does not seem to be much clearance.
I would like to bend the stalk a little to bring it closer to the steering wheel.
Post #311288 24th Feb 2014 4:34pm
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
I managed to get my phone mounted on that angled surface without bending that stalk. I used a cheap windscreen phone mount from Tesco which the suction mount arm can be taken off then superglued the mount to the dash (I did use No Nails tape but going over bumps etc meant it fell off). The stalk clears when indicating even when full beam on. There is a photo in my gallery. 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #311296 24th Feb 2014 4:46pm
Laurie
The horn won't work if you bend it.
....or, actually, it will work non stop.
Post #311299 24th Feb 2014 4:55pm
JWL
My eldest(autistic) son bent mine not long after I bought the motor, I had to straighten it out as when full beam was on it hit the spokes on the steering wheel. That was 4 years ago and it still works, if you try, be gentle.
Post #311306 24th Feb 2014 5:14pm
Merlin
I had to bend mine as I bought a sh*tpart replacement. Why they don't just make parts to fit, rather than lose another customer, I don't know. It fouled the dash when on full beam. I held it in some grips and bent it with some more grips. You can't have enough grips in a tool box!
Merlin
Post #311313 24th Feb 2014 5:25pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Not a Puma but I've deliberately bent both the windscreen wiper stalk and indicator stalk on my Td5.
I'm 6'4 and the knees got in the way.
Everything still works fine.
Trick seems to be two pairs of grips and make sure it's the metal bending and you're not stressing anything else.
Maybe moved them 1/2 an inch each? Enough anyway. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #311344 24th Feb 2014 7:23pm
landy andy
Bent both of mine on Td5, and this weekend on my Tdci so they are better placed for my steering wheel. Just be sensible and all will be ok Thumbs Up Thumbs Up
Andy
Post #311398 24th Feb 2014 9:38pm
shaun.mobile
Ok, big thank you for the responses.
Looks like an 80% chance of success with bending.
Thanks josh for your input and picture, looks like an iPod.
I want some angular adjustment to avoid reflections and I don't want any falling off issues with my Nokia 1520.
Will post back when done.
Post #311455 24th Feb 2014 11:56pm
landy andy
Bend by holding the metal stalk in both hands, so you don't damage switch inside cowl, or to snap off plastic end.
Thumbs Up
Andy
Post #311456 24th Feb 2014 11:58pm
