Home > Puma (Tdci) > ABS/ TC / H.BRAKE LIGHT ON
Tumich
Czech Republic 2008 Defender 110 Puma 2.4 SW Blenheim Silver
HI,
my three Musketier are always on , ABS, TC, Hand BRAKE Light
brake fluid ok, sensors ok, braking bads ok
i thing thatit is the ground problem check all the std. points - ok
then where to find the Graund/earth disconection
anyone an Idea?
thanks JT
Post #309939 20th Feb 2014 3:40pm
A common cause of this is a defective wheel sensor. The only way really to diagnose further is to plug in a diagnostic tool such as Nanocom to see exactly what it's complaining about.
Post #309940 20th Feb 2014 3:45pm
K9F
Both my issues with the same symptoms was the loom chafing and grounding on the chassis.
http://www.defender2.net/forum/topic2394.html?highlight=chafing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #309944 20th Feb 2014 4:03pm
Tumich
The NANOCOM Show the MAin Unit Ground fault
but i checked all the ground points and found any not to be connected,
tiome to time its ok for a while but than again ...
do you have any pic. where did you found the ground problem?
Post #309946 20th Feb 2014 4:09pm
K9F
Pictures were binned ages ago. But basically the loom splits into two sperate looms heading tomards each rear wheel with their own connector. It was shortly before it split where the second occurence was. Dependant on how your loom is routed the most common area is where it routes round the base of your suspension springs over the axle, that was my first experience. Second was where the loom splits into two about halfway on the underside of the truck. You can check the cables as I did from underneath the seat using a multimeter or insulation tester on the modulator connector to point you in the right direction. Then it's a matter of crawling underneath with some cleaning fluid and wiping off the loom to find the chafing. I felt it before I saw it as it was so small.
K9F wrote:
Drive for a while and repeat of symptoms above. Decided to get wiring diagrams out and 'bell out' the cables from under the driver's seat at the modulator. Short circuit offside sensor. Removed rear sensors and loom and as it was smothered in waxoyl had to give it a clean, nothing wrong with that end and all sensors had correct resistance values of about 1000 ohms. Damage was on vehicle side of loom chafed cable approximately a foot from the connector end.
Cut out affected couple of inches.
Nailed in a couple of environmentally sealed inline splices.
Then heatshrunk the area.
Fingers crossed that's an end to it! Thumbs Up
An end to it it was. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310001 20th Feb 2014 6:58pm
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I had the same fault about a year ago. After checking all sensors and wiring as K9F posted I removed, cleaned and greased my ground connections on the chassis and g/b and this solved it for me. 2008 110 XS CSW Stornoway Grey
Post #310127 21st Feb 2014 4:49am
jhnstap
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
If its any help
Had the ABS & TC warning lights on, cant remember the code but it was a Ground/earth fault, Garage new of similar problems and re-earthed the ECU's under driver seat (TD5) back to the battery earth-2 week ago now and no problem since
My initial thought were wheel sensors, but lucky this was a cheap fix, for which I am grateful I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #310130 21st Feb 2014 7:31am
Tumich
Thanks for help,
i will have a look on it deeply on the weekend
Post #310132 21st Feb 2014 7:45am
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
had the lights on mine, but no fault showing on the computer?? turned out to be a ABS sensor wire worn away and shorting out. Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #310446 21st Feb 2014 11:49pm
Lorryman100
Also check that all four wheel speed sensors are seated correctly, just push them in as the air gap may be to large. Thumbs Up
Post #310457 22nd Feb 2014 12:09am
K9F
Had a nightmare trying to set up the gap on my sensors post fault investigation as I ddn't want to potentially damage them by setting them too close perhaps. Ultimately they need to be tapped gently all the way home up to the collar.
Thumbs Up
http://www.defender2.net/forum/topic20879.html?highlight=gap If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310523 22nd Feb 2014 11:22am
